Ana içeriğe geç
HP G62-223CL RAM Replacement
Neye ihtiyacın var
  1. HP G62-223CL RAM Replacement, Battery Removal: adım 1, 2 resimden 1. HP G62-223CL RAM Replacement, Battery Removal: adım 1, 2 resimden 2.
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL RAM Replacement: adım 2, 1 resimden 1.
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Locate three Phillips head retaining screws which secure RAM compartment.
    • Use a Phillips #0 screwdriver to loosen the screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL RAM Replacement: adım 4, 2 resimden 1. HP G62-223CL RAM Replacement: adım 4, 2 resimden 2.
    • Use the tip of a screw driver to press the release clips away from the RAM module.
    • Once the second clip is released, the module will automatically pop up.
  5. HP G62-223CL RAM Replacement: adım 5, 1 resimden 1.
    • Carefully remove module from slot.
    • Be careful not to damage modules when removing them from their slots.
  6. HP G62-223CL RAM Replacement: adım 6, 2 resimden 1. HP G62-223CL RAM Replacement: adım 6, 2 resimden 2.
    • Repeat steps 4 and 5 for additional RAM modules.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Garret Layton
669 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Sullivan Winter 2015 USF Tampa, Team 1-4, Sullivan Winter 2015 üyesi
USFT-SULLIVAN-W15S1G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 624
