Ana içeriğe geç
HP G62-223CL Wireless Card Replacement
Neye ihtiyacın var
  1. HP G62-223CL Wireless Card Replacement, Battery Removal: adım 1, 2 resimden 1. HP G62-223CL Wireless Card Replacement, Battery Removal: adım 1, 2 resimden 2.
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
    FixBot'a Sor
    Yorum Ekle
  2. HP G62-223CL Wireless Card Replacement: adım 2, 1 resimden 1.
    • Carefully remove the battery from its compartment.
    FixBot'a Sor
    Yorum Ekle
  3. HP G62-223CL Wireless Card Replacement, Wireless Card: adım 3, 2 resimden 1. HP G62-223CL Wireless Card Replacement, Wireless Card: adım 3, 2 resimden 2.
    • Locate three Phillips head retaining screws which secure the compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
    FixBot'a Sor
    Yorum Ekle
  4. HP G62-223CL Wireless Card Replacement: adım 4, 3 resimden 1. HP G62-223CL Wireless Card Replacement: adım 4, 3 resimden 2. HP G62-223CL Wireless Card Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to disconnect the gray cable and the black cable from the wireless card.
    FixBot'a Sor
    Yorum Ekle
  5. HP G62-223CL Wireless Card Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the single 4mm screw from the corner of the wireless card.
    FixBot'a Sor
    Yorum Ekle
  6. HP G62-223CL Wireless Card Replacement: adım 6, 1 resimden 1.
    • Carefully lift and pull wireless card. It is removed!
    FixBot'a Sor
    Yorum Ekle
Sonuç
Garret Layton
687 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Sullivan Winter 2015 USF Tampa, Team 1-4, Sullivan Winter 2015 üyesi
USFT-SULLIVAN-W15S1G4
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 1,435
