Ana içeriğe geç
HP G62-234DX RAM Replacement Replacement
Neye ihtiyacın var
  1. HP G62-234DX RAM Replacement Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the computer is turned off, disconnected from the charger, and on a steady surface.
    • Unlock the battery by sliding the button just below it, to the left.
  2. HP G62-234DX RAM Replacement Replacement: adım 2, 1 resimden 1.
    • While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
    • When sliding the new battery back into the socket, you'll know it's secure when you hear a click.
  3. HP G62-234DX RAM Replacement Replacement, RAM: adım 3, 3 resimden 1. HP G62-234DX RAM Replacement Replacement, RAM: adım 3, 3 resimden 2. HP G62-234DX RAM Replacement Replacement, RAM: adım 3, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove three screws from the back panel.
    • Carefully pull the panel off of the back of the laptop to reveal the RAM sticks.
  4. HP G62-234DX RAM Replacement Replacement: adım 4, 3 resimden 1. HP G62-234DX RAM Replacement Replacement: adım 4, 3 resimden 2. HP G62-234DX RAM Replacement Replacement: adım 4, 3 resimden 3.
    • Two clips secure the RAM stick in place, one on each side. Using your fingers, spread the clips away from the RAM stick.
    • When released, the RAM stick will pop up at a slight angle.
    • Lift the RAM stick to an angle of about 30 degrees and slide it out.
    • When handling the RAM stick, only touch the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
    • To install a new RAM stick, slide it in place at about the same angle until it's snug, and then swing it downward until the two clips snap into place.
Sonuç
Cameron Popillo
337 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-1, Ramos Spring 2023 UMass Dartmouth, Team 5-1, Ramos Spring 2023 üyesi
UMASSD-RAMOS-S23S5G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 318
