Ana içeriğe geç
HP G62-234DX Screen Replacement
Neye ihtiyacın var
  1. HP G62-234DX Screen Replacement, Screen: adım 1, 3 resimden 1. HP G62-234DX Screen Replacement, Screen: adım 1, 3 resimden 2. HP G62-234DX Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Make sure the computer is turned off and disconnected from a charger.
    • Place your laptop on a clean, flat surface with the bottom facing up.
    • Slide the battery lock to the left.
    • Slide the battery out from the laptop while holding the lock to the left.
    • Remove the battery.
  2. HP G62-234DX Screen Replacement: adım 2, 3 resimden 1. HP G62-234DX Screen Replacement: adım 2, 3 resimden 2. HP G62-234DX Screen Replacement: adım 2, 3 resimden 3.
    • Flip over the laptop and open the laptop.
    • Using a spudger and opening picks, loosen the screen bezel (outer frame).
    • Start from one side of the bezel and work your way around to the other side.
  3. HP G62-234DX Screen Replacement: adım 3, 3 resimden 1. HP G62-234DX Screen Replacement: adım 3, 3 resimden 2. HP G62-234DX Screen Replacement: adım 3, 3 resimden 3.
    • Lift the screen bezel with your fingers to reveal the screen unit.
  4. HP G62-234DX Screen Replacement: adım 4, 2 resimden 1. HP G62-234DX Screen Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove one 4.0 mm screw on the left and right hinges.
    • Lift the hinges with your fingers.
  5. HP G62-234DX Screen Replacement: adım 5, 2 resimden 1. HP G62-234DX Screen Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the two 3.0 mm screws on the top of the display.
  6. HP G62-234DX Screen Replacement: adım 6, 2 resimden 1. HP G62-234DX Screen Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove a total of four 3.0 mm screws along the edge of both sides of the screen.
  7. HP G62-234DX Screen Replacement: adım 7, 3 resimden 1. HP G62-234DX Screen Replacement: adım 7, 3 resimden 2. HP G62-234DX Screen Replacement: adım 7, 3 resimden 3.
    • Carefully loosen the adhesive under the screen unit using your spudger.
    • Pull off the screen unit using your fingers.
    • The screen is still connected by the display cable.
  8. HP G62-234DX Screen Replacement: adım 8, 3 resimden 1. HP G62-234DX Screen Replacement: adım 8, 3 resimden 2. HP G62-234DX Screen Replacement: adım 8, 3 resimden 3.
    • To disconnect the display cable connector, gently push the tip of a spudger under the clip. Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
    • Lift the protective film slightly and, holding the clip and cable together, gently pull in the direction of the cable to remove the connector from its socket.
    • Safely remove the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kate Ferland
836 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Petersen Fall 2023 UMass Dartmouth, Team 1-1, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 393
