Ana içeriğe geç
Giriş
A brief guide on how to replace the RAM in an HP G62-340.
Parçalar
Hiçbir parça belirtilmedi.
  1. Turn off the computer.
    • Turn off the computer.
    • Unplug the charging cable from the computer.
    • Turn your laptop over and place it on a firm surface.
  2. Locate the memory module compartment. Use a  screwdriver to remove the three Phillips PM2.5x6.0 captive screws and remove the cover on the memory module compartment.
    • Locate the memory module compartment.
    • Use a screwdriver to remove the three Phillips PM2.5x6.0 captive screws and remove the cover on the memory module compartment.
  3. If you need to remove memory before installing the new memory, release the memory using a small wooden tool, or fingernail, to spread the clips holding the memory. If you need to remove memory before installing the new memory, release the memory using a small wooden tool, or fingernail, to spread the clips holding the memory.
    • If you need to remove memory before installing the new memory, release the memory using a small wooden tool, or fingernail, to spread the clips holding the memory.
Sonuç
Yun Yang
321 İtibar
3 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S1-G4, Isaacson Fall 2017 UMass Dartmouth, Team S1-G4, Isaacson Fall 2017 üyesi
UMASSD-ISAACSON-F17S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 5
Her zaman: 117
