Ana içeriğe geç
HP G71t-300 Keyboard Replacement
Neye ihtiyacın var
  1. HP G71t-300 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. HP G71t-300 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. HP G71t-300 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
    • Turn off the computer and remove the charger from the charging port.
    • Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
    FixBot'a Sor
    Yorum Ekle
  2. HP G71t-300 Keyboard Replacement: adım 2, 2 resimden 1. HP G71t-300 Keyboard Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the four screws from the indicated cover.
    • Gently lift and remove the cover.
    FixBot'a Sor
    Yorum Ekle
  3. HP G71t-300 Keyboard Replacement: adım 3, 2 resimden 1. HP G71t-300 Keyboard Replacement: adım 3, 2 resimden 2.
    • Remove the five 6mm screws with the Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. HP G71t-300 Keyboard Replacement: adım 4, 2 resimden 1. HP G71t-300 Keyboard Replacement: adım 4, 2 resimden 2.
    • Pry the keyboard off with a spudger. Be careful not to apply too much pressure and damage any components.
    FixBot'a Sor
    Yorum Ekle
  5. HP G71t-300 Keyboard Replacement: adım 5, 2 resimden 1. HP G71t-300 Keyboard Replacement: adım 5, 2 resimden 2.
    • Disconnect the clip attaching the keyboard wiring to the motherboard. Lift and remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Rohan Mathew
513 İtibar
5 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-3, Oliver Fall 2016 UC Davis, Team 2-3, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G3
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 457
