Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Parçalar
Hiçbir parça belirtilmedi.
  1. Lay the laptop down so the bottom is facing up. Push the slide button, circled in photo 1, to release the battery. Action in picture 2 shows the direction and release.
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. Remove the circled screws. Remove the cover, exposing the hard drive and RAM. Remove the cover, exposing the hard drive and RAM.
    • Remove the circled screws.
    • Remove the cover, exposing the hard drive and RAM.
  3. Remove the 2 circled screws. Use your pry to slide the hard drive over. This unplugs it from its connection and allows it to be removed. Remove the hard drive.
    • Remove the 2 circled screws.
    • Use your pry to slide the hard drive over. This unplugs it from its connection and allows it to be removed.
    • Remove the hard drive.
  4. Push the silver tabs in to release the RAM. When they pop up from the locked position they may be removed.
    • Push the silver tabs in to release the RAM.
    • When they pop up from the locked position they may be removed.
    • Remove the circled screws to release the WiFi card and keyboard.
  5. Remove the panel, exposing the WiFi card. Remove the circle wire connections, make note to which port they were connected to. Remove the WiFi card.
    • Remove the panel, exposing the WiFi card.
    • Remove the circle wire connections, make note to which port they were connected to.
    • Remove the WiFi card.
  6. Flip the laptop over and open it now that the keyboard has been unscrewed. Take your pry bar and go around the outer edge of the keyboard. Popping it free from the bezel. Take your pry bar and go around the outer edge of the keyboard. Popping it free from the bezel.
    • Flip the laptop over and open it now that the keyboard has been unscrewed.
    • Take your pry bar and go around the outer edge of the keyboard. Popping it free from the bezel.
  7. Lift the keyboard up. Remove the connections from the keyboard to the motherboard. Remember each attachments position because they will need to be connected again.
    • Lift the keyboard up.
    • Remove the connections from the keyboard to the motherboard.
    • Remember each attachments position because they will need to be connected again.
  8. Remove the circled screws to release the  bezel from the faceplate. Remove the circled screws to release the  bezel from the faceplate. Remove the circled screws to release the  bezel from the faceplate.
    • Remove the circled screws to release the bezel from the faceplate.
  9. Lift the bezel from the face plate. Disconnect the power connection from the bezel to the motherboard.
    • Lift the bezel from the face plate.
    • Disconnect the power connection from the bezel to the motherboard.
  10. Remove the two screws side-by-side next to each in the red circle. This will be the last layer to remove before reaching the motherboard. This will be the last layer to remove before reaching the motherboard.
    • Remove the two screws side-by-side next to each in the red circle.
    • This will be the last layer to remove before reaching the motherboard.
  11. Carefully detach the highlighted connections. Remove the motherboard from the device.
    • Carefully detach the highlighted connections.
    • Remove the motherboard from the device.
  12. Remove three screws to detach the cooling fan from the motherboard. Remove the last connection. Remove the last connection.
    • Remove three screws to detach the cooling fan from the motherboard.
    • Remove the last connection.
Sonuç
Nicholas Castro
711 İtibar
6 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S1-G5, Simcock Spring 2019 UMass Dartmouth, Team S1-G5, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S1G5
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 60
