Ana içeriğe geç
HP G72 Hard Drive Replacement
Neye ihtiyacın var
  1. HP G72 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. HP G72 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. HP G72 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
    FixBot'a Sor
    Yorum Ekle
  2. HP G72 Hard Drive Replacement: adım 2, 3 resimden 1. HP G72 Hard Drive Replacement: adım 2, 3 resimden 2. HP G72 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Loosen the two Phillips 2.5×6.0 captive screws that secure the hard drive cover to the computer.
    • The cover is snapped in by some clips. Use a plastic opening tool on both sides to remove the cover.
    FixBot'a Sor
    Yorum Ekle
  3. HP G72 Hard Drive Replacement: adım 3, 3 resimden 1. HP G72 Hard Drive Replacement: adım 3, 3 resimden 2. HP G72 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Remove the cover
    • Remove the four Phillips M2.5x5.0 screws
    • Disconnect the hard drive cable from the system board.
    FixBot'a Sor
    Yorum Ekle
  4. HP G72 Hard Drive Replacement: adım 4, 3 resimden 1. HP G72 Hard Drive Replacement: adım 4, 3 resimden 2. HP G72 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Remove the hard drive from the hard drive bay
    • Remove the hard drive cable from the drive.
    • Remove the four (two on either side) Phillips M3.0×4.0 screws that secure the hard drive bracket to the hard drive
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
oldturkey03
856.867 İtibar
123 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 46
Her zaman: 8,100
