Ana içeriğe geç
HP HDX 16-1160US DVD Drive Replacement
Neye ihtiyacın var
  1. HP HDX 16-1160US DVD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US DVD Drive Replacement: adım 2, 3 resimden 1. HP HDX 16-1160US DVD Drive Replacement: adım 2, 3 resimden 2. HP HDX 16-1160US DVD Drive Replacement: adım 2, 3 resimden 3.
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US DVD Drive Replacement: adım 3, 1 resimden 1.
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US DVD Drive Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove the three 4mm screws using Phillips #1 screw driver.
    • Remove the four 6mm screws using Phillips #1 screw driver.
    • Remove the two 3mm screws using Phillips #1 screw driver.
  5. HP HDX 16-1160US DVD Drive Replacement: adım 5, 1 resimden 1.
    • Using your fingers, pry off the speaker cover.
  6. HP HDX 16-1160US DVD Drive Replacement: adım 6, 3 resimden 1. HP HDX 16-1160US DVD Drive Replacement: adım 6, 3 resimden 2. HP HDX 16-1160US DVD Drive Replacement: adım 6, 3 resimden 3.
    • Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
    • Remove the chrome keyboard cover.
    • Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
  7. HP HDX 16-1160US DVD Drive Replacement: adım 7, 3 resimden 1. HP HDX 16-1160US DVD Drive Replacement: adım 7, 3 resimden 2. HP HDX 16-1160US DVD Drive Replacement: adım 7, 3 resimden 3.
    • Locate and remove the two 4mm screws with the Phillips #1 screw driver.
  8. HP HDX 16-1160US DVD Drive Replacement: adım 8, 2 resimden 1. HP HDX 16-1160US DVD Drive Replacement: adım 8, 2 resimden 2.
    • Using your hands, pull the keyboard out.
    • Do not pull completely off because there is a grey strip connecting it to the laptop itself.
  9. HP HDX 16-1160US DVD Drive Replacement: adım 9, 2 resimden 1. HP HDX 16-1160US DVD Drive Replacement: adım 9, 2 resimden 2.
    • Lift the black tab using the plastic opening tool.
    • Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
  10. HP HDX 16-1160US DVD Drive Replacement, DVD Drive: adım 10, 1 resimden 1.
    • Use the Phillips #1 Screw Driver to unscrew the 5mm screw.
  11. HP HDX 16-1160US DVD Drive Replacement: adım 11, 1 resimden 1.
    • Flip over the device so that the bottom side is facing up.
    • Use the Phillips #1 Screw Driver to unscrew the 7mm screw near the center of the device.
  12. HP HDX 16-1160US DVD Drive Replacement: adım 12, 1 resimden 1.
    • Push down and pull out the DVD on the left side of the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Marshall Reid
527 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-38, Maness Spring 2014 Cal Poly, Team 12-38, Maness Spring 2014 üyesi
CPSU-MANESS-S14S12G38
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 1,445
