Ana içeriğe geç
HP HDX 16-1160US RAM Replacement
Neye ihtiyacın var
  1. HP HDX 16-1160US RAM Replacement, RAM: adım 1, 2 resimden 1. HP HDX 16-1160US RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Flip the device over so that the bottom side is facing up and use the Phillips #1 Screw Driver to remove the four 4mm screws on the cover panel.
    • Lift the panel to remove it from the device.
  2. HP HDX 16-1160US RAM Replacement: adım 2, 3 resimden 1. HP HDX 16-1160US RAM Replacement: adım 2, 3 resimden 2. HP HDX 16-1160US RAM Replacement: adım 2, 3 resimden 3.
    • Remove the RAM by placing your thumbs on the silver tabs on each side of the RAM stick and pulling the tabs away from the RAM stick.
    • The RAM stick should "flip" up when it is released from its holders.
    • Pull the RAM stick toward you to remove it.
    • Repeat the above step to remove the second RAM stick
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Marshall Reid
527 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-38, Maness Spring 2014 Cal Poly, Team 12-38, Maness Spring 2014 üyesi
CPSU-MANESS-S14S12G38
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 688
