Ana içeriğe geç
HP LaserJet 1160 or 1320 Formatter Replacement
Neye ihtiyacın var
  1. HP LaserJet 1160 or 1320 Formatter Replacement, Left Side Cover: adım 1, 3 resimden 1. HP LaserJet 1160 or 1320 Formatter Replacement, Left Side Cover: adım 1, 3 resimden 2. HP LaserJet 1160 or 1320 Formatter Replacement, Left Side Cover: adım 1, 3 resimden 3.
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Formatter Replacement, Formatter: adım 2, 3 resimden 1. HP LaserJet 1160 or 1320 Formatter Replacement, Formatter: adım 2, 3 resimden 2. HP LaserJet 1160 or 1320 Formatter Replacement, Formatter: adım 2, 3 resimden 3.
    • Remove 2 screws on the I/O port cover.
    • Remove 6 screws on the formatter.
    • Disconnect 3 connectors from the formatter.
    • Disconnect 2 flat flexible cables from the formatter.
    • Remove the formatter from the printer.
    • Be careful not to fold, crease, or tear flat flexible cables.
    • The I/O port cover will need to be transferred to the new formatter before installing it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
jdp23
1.302 İtibar
23 adet Kılavuz yazıldı
Bir Yorum
Additional connector attached to bottom left of board ignored
R F Rossiter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,181
