Ana içeriğe geç
HP LaserJet 1160 or 1320 Laser Assembly Replacement
Neye ihtiyacın var
  1. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Left Side Cover: adım 1, 3 resimden 1. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Left Side Cover: adım 1, 3 resimden 2. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Left Side Cover: adım 1, 3 resimden 3.
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Right Side Cover: adım 2, 3 resimden 1. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Right Side Cover: adım 2, 3 resimden 2. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Right Side Cover: adım 2, 3 resimden 3.
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Back Cover: adım 3, 3 resimden 1. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Back Cover: adım 3, 3 resimden 2. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Back Cover: adım 3, 3 resimden 3.
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
  4. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Top Cover: adım 4, 3 resimden 1. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Top Cover: adım 4, 3 resimden 2. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Top Cover: adım 4, 3 resimden 3.
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  5. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Top Cover: adım 5, 1 resimden 1.
    • Disconnect the control panel cable and remove the top cover.
  6. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Laser Assembly: adım 6, 3 resimden 1. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Laser Assembly: adım 6, 3 resimden 2. HP LaserJet 1160 or 1320 Laser Assembly Replacement, Laser Assembly: adım 6, 3 resimden 3.
    • Remove one cable from the top of the laser assembly and one cable from the right side of the laser assembly.
    • Remove 4 screws from the laser assembly.
    • Remove all cables from the cable clip on the side of the laser assembly and remove it from the printer.
Sonuç
jdp23
1.302 İtibar
23 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 472
