Ana içeriğe geç
HP LaserJet 1160 or 1320 Pickup Roller Replacement
Neye ihtiyacın var
  1. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Left Side Cover: adım 1, 3 resimden 1. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Left Side Cover: adım 1, 3 resimden 2. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Left Side Cover: adım 1, 3 resimden 3.
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Right Side Cover: adım 2, 3 resimden 1. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Right Side Cover: adım 2, 3 resimden 2. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Right Side Cover: adım 2, 3 resimden 3.
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Back Cover: adım 3, 3 resimden 1. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Back Cover: adım 3, 3 resimden 2. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Back Cover: adım 3, 3 resimden 3.
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
    для чистки соленоида зад снимать не обязательно.
    liv 63 - Yanıt
  4. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Top Cover: adım 4, 3 resimden 1. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Top Cover: adım 4, 3 resimden 2. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Top Cover: adım 4, 3 resimden 3.
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  5. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Top Cover: adım 5, 1 resimden 1.
    • Disconnect the control panel cable and remove the top cover.
  6. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Duplexer Tray: adım 6, 2 resimden 1. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Duplexer Tray: adım 6, 2 resimden 2.
    • Pull on the blue-green tab to release the duplexer tray.
  7. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Cartridge Door: adım 7, 2 resimden 1. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Cartridge Door: adım 7, 2 resimden 2.
    • Remove 2 screws from the front of the printer.
    • Remove the cartridge door.
  8. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Pickup Roller: adım 8, 3 resimden 1. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Pickup Roller: adım 8, 3 resimden 2. HP LaserJet 1160 or 1320 Pickup Roller Replacement, Pickup Roller: adım 8, 3 resimden 3.
    • Remove the pickup roller by rotating the white tabs upwards and pulling them outwards.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
jdp23
1.302 İtibar
23 adet Kılavuz yazıldı
6 Yorum
no need to remove any sides....
donrock102 - Yanıt
Just go straight to step 8, that’s all you need to do!
PCSG - Yanıt
Step 6 and Step 8 are the only steps necessary.
sadowski72001 - Yanıt
Ok here is the pickup roller replacement procedure: 1. Turn off the printer and unplug the power cord and and network or USB cables; 2. Remove toner cartridge; 3. Remove paper tray; 4. Reposition printer on its back (the side where power/network/USB cables connect); 5. Release duplexer tray (step 6 in the procedure outlined above); 6. Using a needle-nose pliers, move the white handles outward and rotate them upward (first image in step 8 above); 7. Once you’ve rotated the white tabs so they look like picture 2 in step 8 above, pull them outward. The left tab will come off; 8. Move the rollers to the left and they will be free. 9. Reverse the steps to reassemble.
Dana Sandburg - Yanıt
No hay que desmontar nada. En este video lo explica.
No need dismount any part. Look at this video.
'''https://youtu.be/XpaX7r0urZE'''
Javier Munné - Yanıt
#Javier Great video - thanks.
Procedure also works for P2015 printer
Not Myself - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 29
Her zaman: 8,259
