Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Pull on the two tabs on the back of the printer to release the left side cover.
Remove the cover by rotating it towards the front of the printer.
With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
Lift the cover off of the printer.
Remove 4 screws on the back of the printer.
Remove the back cover.
Remove 2 screws on the back of the printer, one on the left, and one on the front.
Disconnect the control panel cable and remove the top cover.
