Ana içeriğe geç
HP LaserJet P1102w Drive Belt Replacement
Neye ihtiyacın var
    1. HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: adım 1, 3 resimden 1. HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: adım 1, 3 resimden 2. HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: adım 1, 3 resimden 3.
      • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
      • Pry carefully to not break any plastic.
      FixBot'a Sor
      Yorum Ekle
    2. HP LaserJet P1102w Drive Belt Replacement: adım 2, 2 resimden 1. HP LaserJet P1102w Drive Belt Replacement: adım 2, 2 resimden 2.
      • Now that the pry points are free lift up the front panel.
      FixBot'a Sor
      Yorum Ekle
    3. HP LaserJet P1102w Drive Belt Replacement: adım 3, 2 resimden 1. HP LaserJet P1102w Drive Belt Replacement: adım 3, 2 resimden 2.
      • Unscrew the #1 Phillips screw 6mm on the back of the printer.
      FixBot'a Sor
      Yorum Ekle
    4. HP LaserJet P1102w Drive Belt Replacement: adım 4, 3 resimden 1. HP LaserJet P1102w Drive Belt Replacement: adım 4, 3 resimden 2. HP LaserJet P1102w Drive Belt Replacement: adım 4, 3 resimden 3.
      • Using the plastic spudger, remove the button housing from the top left of printer.
      FixBot'a Sor
      Yorum Ekle
    5. HP LaserJet P1102w Drive Belt Replacement: adım 5, 2 resimden 1. HP LaserJet P1102w Drive Belt Replacement: adım 5, 2 resimden 2.
      • Once the housing is removed, remove the three buttons.
      FixBot'a Sor
      Yorum Ekle
    6. HP LaserJet P1102w Drive Belt Replacement: adım 6, 3 resimden 1. HP LaserJet P1102w Drive Belt Replacement: adım 6, 3 resimden 2. HP LaserJet P1102w Drive Belt Replacement: adım 6, 3 resimden 3.
      • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
      FixBot'a Sor
      Yorum Ekle
    7. HP LaserJet P1102w Drive Belt Replacement: adım 7, 2 resimden 1. HP LaserJet P1102w Drive Belt Replacement: adım 7, 2 resimden 2.
      • With all pry points free, remove the side panel.
      FixBot'a Sor
      Yorum Ekle
    1. HP LaserJet P1102w Drive Belt Replacement, Drive Belt: adım 8, 3 resimden 1. HP LaserJet P1102w Drive Belt Replacement, Drive Belt: adım 8, 3 resimden 2. HP LaserJet P1102w Drive Belt Replacement, Drive Belt: adım 8, 3 resimden 3.
      • Refer to the prerequisite guide to take off the front panel off.
      • With a #1 Phillips screwdriver remove only the top Phillips 60mm screw.
      • With the spudger pry the side panel off. There will be four flanges to unhitch.
      FixBot'a Sor
      Yorum Ekle
    2. HP LaserJet P1102w Drive Belt Replacement: adım 9, 2 resimden 1. HP LaserJet P1102w Drive Belt Replacement: adım 9, 2 resimden 2.
      • With side panel removed, there will be four Phillips 60mm screws to unscrew using a #1 Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. HP LaserJet P1102w Drive Belt Replacement: adım 10, 3 resimden 1. HP LaserJet P1102w Drive Belt Replacement: adım 10, 3 resimden 2. HP LaserJet P1102w Drive Belt Replacement: adım 10, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove top two big gears using tweezers.
      • Take note of gear placement.
      FixBot'a Sor
      Yorum Ekle
    4. HP LaserJet P1102w Drive Belt Replacement: adım 11, 3 resimden 1. HP LaserJet P1102w Drive Belt Replacement: adım 11, 3 resimden 2. HP LaserJet P1102w Drive Belt Replacement: adım 11, 3 resimden 3.
      • With the #1 Phillips screwdriver remove the 60mm Phillips screw holding the belt tension-er.
      • With the screw removed, pull tension-er out.
      • Use tweezers to remove the loose drive belt.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jerome Etten
784 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Stout, Team S6-G4, Ogden Fall 2018 UW Stout, Team S6-G4, Ogden Fall 2018 üyesi
UWSTOUT-OGDEN-F18S6G4
4 Üyeler
12 adet Kılavuz yazıldı
3Kılavuz Yorumları
the tight side panel clips make this a difficult procedure, so take care both disassembling and assembling, for example make sure the power button is aligned with the level components behind before you push to clip the front home, as misalignment can break or dislocate internal parts.
Peter Taffs - Yanıt Paylaş
Que dois je faire si mon imprimante fait beaucoup de bruit en imprimant et que la totalité de feuille imprimée ne sort pas?
anelka VILPIGUE - Yanıt Paylaş
In my case, the roller is worn out. I haven't been able to find a replacement. Can you give me the part code so I can buy it?
EleCom - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 28
Son 30 gün: 94
Her zaman: 4,731
