Ana içeriğe geç
HP LaserJet P1102w Power Plug Replacement
Neye ihtiyacın var
  1. HP LaserJet P1102w Power Plug Replacement, Left Side Panel: adım 1, 3 resimden 1. HP LaserJet P1102w Power Plug Replacement, Left Side Panel: adım 1, 3 resimden 2. HP LaserJet P1102w Power Plug Replacement, Left Side Panel: adım 1, 3 resimden 3.
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Power Plug Replacement: adım 2, 2 resimden 1. HP LaserJet P1102w Power Plug Replacement: adım 2, 2 resimden 2.
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Power Plug Replacement: adım 3, 2 resimden 1. HP LaserJet P1102w Power Plug Replacement: adım 3, 2 resimden 2.
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Power Plug Replacement: adım 4, 3 resimden 1. HP LaserJet P1102w Power Plug Replacement: adım 4, 3 resimden 2. HP LaserJet P1102w Power Plug Replacement: adım 4, 3 resimden 3.
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Power Plug Replacement: adım 5, 2 resimden 1. HP LaserJet P1102w Power Plug Replacement: adım 5, 2 resimden 2.
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Power Plug Replacement: adım 6, 3 resimden 1. HP LaserJet P1102w Power Plug Replacement: adım 6, 3 resimden 2. HP LaserJet P1102w Power Plug Replacement: adım 6, 3 resimden 3.
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Power Plug Replacement: adım 7, 2 resimden 1. HP LaserJet P1102w Power Plug Replacement: adım 7, 2 resimden 2.
    • With all pry points free, remove the side panel.
  8. HP LaserJet P1102w Power Plug Replacement, Power Plug: adım 8, 2 resimden 1. HP LaserJet P1102w Power Plug Replacement, Power Plug: adım 8, 2 resimden 2.
    • The power plug will be held together with one Phillips screw 7mm and wire connection.
  9. HP LaserJet P1102w Power Plug Replacement: adım 9, 2 resimden 1. HP LaserJet P1102w Power Plug Replacement: adım 9, 2 resimden 2.
    • Unplug wire connector and unscrew the Phillips 7mm screw with #1 Phillips screw driver.
  10. HP LaserJet P1102w Power Plug Replacement: adım 10, 3 resimden 1. HP LaserJet P1102w Power Plug Replacement: adım 10, 3 resimden 2. HP LaserJet P1102w Power Plug Replacement: adım 10, 3 resimden 3.
    • Apply pressure using spudger on top of the power plug to release it from metal housing. While doing that pull the power plug out.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Myles Nofsinger
274 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team S6-G4, Ogden Fall 2018 UW Stout, Team S6-G4, Ogden Fall 2018 üyesi
UWSTOUT-OGDEN-F18S6G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 1,608
