Ana içeriğe geç
HP Laserjet Pro 200 Color MFP Toner Cartridge Drawer Replacement
Neye ihtiyacın var
  1. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement, Toner Cartridge Drawer: adım 1, 1 resimden 1.
    • Open the front cover by grasping the edge and pulling it outwards.
  2. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: adım 2, 1 resimden 1.
    • Pull out the toner cartridge drawer by using the handle as shown.
  3. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: adım 3, 1 resimden 1.
    • Use the handles built into the toner cartridges to remove them by pulling straight upwards.
    • Remove all 4 toner cartridges.
    • Each toner cartridge has a specific place depending on color. The right locations for each cartridge can be found by looking at the colored stickers on the right side of the drawer. This is important to note for reassembly.
  4. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: adım 4, 2 resimden 1. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: adım 4, 2 resimden 2.
    • There are 2 locks on the inner walls of the sides of the printer which need to be removed in order to have access to the toner drawer.
    • Use the opening tool or a small flathead screwdriver to depress the small button on the inside of the lock. This button keeps the lock from moving.
    • The second picture shows what these lock assemblies look like.
  5. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: adım 5, 3 resimden 1. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: adım 5, 3 resimden 2. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: adım 5, 3 resimden 3.
    • While continuing to depress the button, use your finger to grab ahold of the lock.
    • Push it forwards into the printer and maintain pressure on the lock.
    • Pivot the back end of the lock away from the inner wall of the printer and towards you until it pops out.
  6. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: adım 6, 1 resimden 1.
    • Repeat steps 4 and 5 for the lock on the opposite side of the printer.
  7. HP Laserjet Pro 200 Color MFP  Toner Cartridge Drawer Replacement: adım 7, 1 resimden 1.
    • Pull out the faulty ink cartridge drawer and replace it with a functioning drawer.
Sonuç
To reassemble your device, follow the instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Kendall Gentzen
999 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S9-G14, Maness Spring 2019 Cal Poly, Team S9-G14, Maness Spring 2019 üyesi
CPSU-MANESS-S19S9G14
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 73
Her zaman: 4,485
