Ana içeriğe geç
HP Media Center 876x Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Media Center 876x Cooling Fan Replacement, Side Panel: adım 1, 2 resimden 1. HP Media Center 876x Cooling Fan Replacement, Side Panel: adım 1, 2 resimden 2.
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Cooling Fan Replacement: adım 2, 3 resimden 1. HP Media Center 876x Cooling Fan Replacement: adım 2, 3 resimden 2. HP Media Center 876x Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 1. HP Media Center 876x Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 2.
    • Apply great pressure with fingers on the tabs of the fan casing.
    • While applying pressure, pull the casing upwards to remove.
  4. HP Media Center 876x Cooling Fan Replacement: adım 4, 2 resimden 1. HP Media Center 876x Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Simultaneously pull the four corner tabs outward.
    • Grab the center of the fan and slide it, smoothly, outward.
  5. HP Media Center 876x Cooling Fan Replacement: adım 5, 2 resimden 1. HP Media Center 876x Cooling Fan Replacement: adım 5, 2 resimden 2.
    • Remove the fan completely from its casing.
    • Take care not to damage any plastic parts or wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Balakrishnan Pillai
1.003 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-1, Benson Spring 2014 Clemson, Team 6-1, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G1
3 Üyeler
15 adet Kılavuz yazıldı
Bir Yorum
Cpu not start
Sameer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 496
