Ana içeriğe geç
HP Media Center 876x Optical Drive Replacement
Neye ihtiyacın var
  1. HP Media Center 876x Optical Drive Replacement, Side Panel: adım 1, 2 resimden 1. HP Media Center 876x Optical Drive Replacement, Side Panel: adım 1, 2 resimden 2.
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Optical Drive Replacement: adım 2, 3 resimden 1. HP Media Center 876x Optical Drive Replacement: adım 2, 3 resimden 2. HP Media Center 876x Optical Drive Replacement: adım 2, 3 resimden 3.
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Optical Drive Replacement, Front Cover: adım 3, 2 resimden 1. HP Media Center 876x Optical Drive Replacement, Front Cover: adım 3, 2 resimden 2.
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
  4. HP Media Center 876x Optical Drive Replacement: adım 4, 1 resimden 1.
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
  5. HP Media Center 876x Optical Drive Replacement: adım 5, 2 resimden 1. HP Media Center 876x Optical Drive Replacement: adım 5, 2 resimden 2.
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
  6. HP Media Center 876x Optical Drive Replacement, Optical Drive: adım 6, 3 resimden 1. HP Media Center 876x Optical Drive Replacement, Optical Drive: adım 6, 3 resimden 2. HP Media Center 876x Optical Drive Replacement, Optical Drive: adım 6, 3 resimden 3.
    • Identify the optical drive.
    • Pull the molex connectors out of the posterior end of the optical drive.
  7. HP Media Center 876x Optical Drive Replacement: adım 7, 3 resimden 1. HP Media Center 876x Optical Drive Replacement: adım 7, 3 resimden 2. HP Media Center 876x Optical Drive Replacement: adım 7, 3 resimden 3.
    • Pull the ribbon cable out of the back of the optical drive.
  8. HP Media Center 876x Optical Drive Replacement: adım 8, 3 resimden 1. HP Media Center 876x Optical Drive Replacement: adım 8, 3 resimden 2. HP Media Center 876x Optical Drive Replacement: adım 8, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the two 5 mm screws that fasten the optical drive into its port.
    • Gently pull the optical drive through the front cavity.
  9. HP Media Center 876x Optical Drive Replacement: adım 9, 2 resimden 1. HP Media Center 876x Optical Drive Replacement: adım 9, 2 resimden 2.
    • Remove the optical drive completely from its port.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Balakrishnan Pillai
1.003 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-1, Benson Spring 2014 Clemson, Team 6-1, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G1
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 400
