Ana içeriğe geç
HP Media Center 876x TV Tuner Card Replacement
Neye ihtiyacın var
  1. HP Media Center 876x TV Tuner Card Replacement, Side Panel: adım 1, 2 resimden 1. HP Media Center 876x TV Tuner Card Replacement, Side Panel: adım 1, 2 resimden 2.
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x TV Tuner Card Replacement: adım 2, 3 resimden 1. HP Media Center 876x TV Tuner Card Replacement: adım 2, 3 resimden 2. HP Media Center 876x TV Tuner Card Replacement: adım 2, 3 resimden 3.
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x TV Tuner Card Replacement, TV Tuner Card: adım 3, 2 resimden 1. HP Media Center 876x TV Tuner Card Replacement, TV Tuner Card: adım 3, 2 resimden 2.
    • Identify the TV tuner card (distal from the cooling fan, in the lower-left corner of the tower).
    • Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the TV tuner card into its slot.
  4. HP Media Center 876x TV Tuner Card Replacement: adım 4, 2 resimden 1. HP Media Center 876x TV Tuner Card Replacement: adım 4, 2 resimden 2.
    • Gently pull the card vertically out of its port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Balakrishnan Pillai
1.003 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-1, Benson Spring 2014 Clemson, Team 6-1, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G1
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 613
