Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The HP Media Center 876x is capable of receiving television service through its TV tuner card. If you are unable to receive proper service, the TV tuner card may require replacement.
Neye ihtiyacın var
Identify the TV tuner card (distal from the cooling fan, in the lower-left corner of the tower).
Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the TV tuner card into its slot.
Bir başkası bu kılavuzu tamamladı.
