Ana içeriğe geç
HP Mini 1000 RAM Replacement
Neye ihtiyacın var
  1. HP Mini 1000 RAM Replacement, Battery: adım 1, 2 resimden 1. HP Mini 1000 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
    FixBot'a Sor
    Yorum Ekle
  2. HP Mini 1000 RAM Replacement: adım 2, 1 resimden 1.
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
    FixBot'a Sor
    Yorum Ekle
  3. HP Mini 1000 RAM Replacement, RAM: adım 3, 2 resimden 1. HP Mini 1000 RAM Replacement, RAM: adım 3, 2 resimden 2.
    • Before proceeding, slide the right battery release latch to the unlocked position nearest the center of the computer.
    • Use the tip of a spudger to slide the RAM compartment cover release latch away from the center of the computer.
    • At this point, the edge of the RAM compartment cover nearest the battery compartment should pop up from the lower case.
    FixBot'a Sor
    Yorum Ekle
  4. HP Mini 1000 RAM Replacement: adım 4, 1 resimden 1.
    • Remove the RAM compartment cover from the lower case.
    FixBot'a Sor
    Yorum Ekle
  5. HP Mini 1000 RAM Replacement: adım 5, 2 resimden 1. HP Mini 1000 RAM Replacement: adım 5, 2 resimden 2.
    • Use your fingers to simultaneously pull both RAM retaining arms away from the center of the RAM chip.
    • The RAM chip should pop up slightly from its socket.
    • Pull the RAM chip out of its socket and remove it from the Mini 1000.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 48
Her zaman: 4,944
