Ana içeriğe geç
HP Mini 110-1046NR Memory Card Replacement
Neye ihtiyacın var
  1. HP Mini 110-1046NR Memory Card Replacement, Battery: adım 1, 3 resimden 1. HP Mini 110-1046NR Memory Card Replacement, Battery: adım 1, 3 resimden 2. HP Mini 110-1046NR Memory Card Replacement, Battery: adım 1, 3 resimden 3.
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: adım 2, 3 resimden 1. HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: adım 2, 3 resimden 2. HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: adım 2, 3 resimden 3.
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
  3. HP Mini 110-1046NR Memory Card Replacement, Memory Card: adım 3, 3 resimden 1. HP Mini 110-1046NR Memory Card Replacement, Memory Card: adım 3, 3 resimden 2. HP Mini 110-1046NR Memory Card Replacement, Memory Card: adım 3, 3 resimden 3.
    • Carefully push the clips to the side, away from the memory card.
    • Note: The memory module is spring-loaded and will pop out when the clips are detatched.
    • Slide the memory card straight out, holding it as shown to avoid getting skin oils on the electrical contacts.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jared Cooper
649 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-1, Benson Fall 2013 Clemson, Team 14-1, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 1,302
