Ana içeriğe geç
HP Mini 110-3131dx Hard Drive Replacement
Neye ihtiyacın var
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Hard Drive Replacement, Back Cover: adım 2, 2 resimden 1. HP Mini 110-3131dx Hard Drive Replacement, Back Cover: adım 2, 2 resimden 2.
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Hard Drive Replacement: adım 4, 2 resimden 1. HP Mini 110-3131dx Hard Drive Replacement: adım 4, 2 resimden 2.
    • Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
    • Pull the hard drive out of the laptop.
    • Put the hard drive in an anti-static bag to decrease the likelihood of harming it with static electricity.
Sonuç
To reinstall a new or old hard drive, follow these instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
aarondcollege
1.297 İtibar
10 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Cagle Fall 2016 USF Tampa, Team 2-4, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S2G4
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 1,408
