Ana içeriğe geç
HP Mini 110-3131dx Keyboard Replacement
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Keyboard Replacement, Back Cover: adım 2, 2 resimden 1. HP Mini 110-3131dx Keyboard Replacement, Back Cover: adım 2, 2 resimden 2.
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Keyboard Replacement: adım 4, 3 resimden 1. HP Mini 110-3131dx Keyboard Replacement: adım 4, 3 resimden 2. HP Mini 110-3131dx Keyboard Replacement: adım 4, 3 resimden 3.
    • Turn the laptop upright and open it.
    • Disconnect the clips located around the perimeter of the keyboard.
    • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
    • Start either above the esc key or the delete key.
    • Pull the keyboard with your fingers until it comes out on both sides.
    • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
  4. HP Mini 110-3131dx Keyboard Replacement: adım 5, 1 resimden 1.
    • Tilt the keyboard toward you to reveal the ribbon cable.
    • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
    • Pull the ribbon cable out of its container.
Sonuç
To install a different keyboard, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
aarondcollege
1.285 İtibar
10 adet Kılavuz yazıldı
USF Tampa, Team 2-4, Cagle Fall 2016 USF Tampa, Team 2-4, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S2G4
5 Üyeler
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 2,000
