Ana içeriğe geç
HP Mini 110-3735dx Hard Drive Cage Replacement
Neye ihtiyacın var
  1. HP Mini 110-3735dx Hard Drive Cage Replacement, Battery: adım 1, 3 resimden 1. HP Mini 110-3735dx Hard Drive Cage Replacement, Battery: adım 1, 3 resimden 2. HP Mini 110-3735dx Hard Drive Cage Replacement, Battery: adım 1, 3 resimden 3.
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Hard Drive Cage Replacement: adım 2, 2 resimden 1. HP Mini 110-3735dx Hard Drive Cage Replacement: adım 2, 2 resimden 2.
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Hard Drive Cage Replacement, Backcover: adım 3, 3 resimden 1. HP Mini 110-3735dx Hard Drive Cage Replacement, Backcover: adım 3, 3 resimden 2. HP Mini 110-3735dx Hard Drive Cage Replacement, Backcover: adım 3, 3 resimden 3.
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Hard Drive Cage Replacement, Hard Drive Cage: adım 4, 1 resimden 1.
    • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Hard Drive Cage Replacement: adım 5, 3 resimden 1. HP Mini 110-3735dx Hard Drive Cage Replacement: adım 5, 3 resimden 2. HP Mini 110-3735dx Hard Drive Cage Replacement: adım 5, 3 resimden 3.
    • Lift the hard drive cage by pulling the tape upward.
    • Start by pulling the tape from the side with the keyboard symbol.
  6. HP Mini 110-3735dx Hard Drive Cage Replacement: adım 6, 2 resimden 1. HP Mini 110-3735dx Hard Drive Cage Replacement: adım 6, 2 resimden 2.
    • Unplug the cable connecting to the hard drive.
Sonuç
Tyrone Williams
905 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Catania Spring 2016 UMass Dartmouth, Team 4-1, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 267
