Ana içeriğe geç
HP Mini 110-3735dx Keyboard Replacement
Neye ihtiyacın var
  1. HP Mini 110-3735dx Keyboard Replacement, Battery: adım 1, 3 resimden 1. HP Mini 110-3735dx Keyboard Replacement, Battery: adım 1, 3 resimden 2. HP Mini 110-3735dx Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
    FixBot'a Sor
    Yorum Ekle
  2. HP Mini 110-3735dx Keyboard Replacement: adım 2, 2 resimden 1. HP Mini 110-3735dx Keyboard Replacement: adım 2, 2 resimden 2.
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
    FixBot'a Sor
    Yorum Ekle
  3. HP Mini 110-3735dx Keyboard Replacement, Backcover: adım 3, 3 resimden 1. HP Mini 110-3735dx Keyboard Replacement, Backcover: adım 3, 3 resimden 2. HP Mini 110-3735dx Keyboard Replacement, Backcover: adım 3, 3 resimden 3.
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
    FixBot'a Sor
    Yorum Ekle
  4. HP Mini 110-3735dx Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. HP Mini 110-3735dx Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
    FixBot'a Sor
    Yorum Ekle
  5. HP Mini 110-3735dx Keyboard Replacement: adım 5, 2 resimden 1. HP Mini 110-3735dx Keyboard Replacement: adım 5, 2 resimden 2.
    • Flip the laptop over, and open it up.
    • Don't worry! No pieces will fall out.
    FixBot'a Sor
    Yorum Ekle
  6. HP Mini 110-3735dx Keyboard Replacement: adım 6, 2 resimden 1. HP Mini 110-3735dx Keyboard Replacement: adım 6, 2 resimden 2.
    • With the keyboard facing you, pull the black bezel upward until its loose.
    • You should hear three clicks.
    FixBot'a Sor
    Yorum Ekle
  7. HP Mini 110-3735dx Keyboard Replacement: adım 7, 2 resimden 1. HP Mini 110-3735dx Keyboard Replacement: adım 7, 2 resimden 2.
    • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
    FixBot'a Sor
    Yorum Ekle
  8. HP Mini 110-3735dx Keyboard Replacement: adım 8, 1 resimden 1.
    • Pull up the keyboard from the bottom corners exposing the keyboard cable.
    FixBot'a Sor
    Yorum Ekle
  9. HP Mini 110-3735dx Keyboard Replacement: adım 9, 2 resimden 1. HP Mini 110-3735dx Keyboard Replacement: adım 9, 2 resimden 2.
    • Lift the black holder connected to the keyboard cable until it points up.
    FixBot'a Sor
    Yorum Ekle
  10. HP Mini 110-3735dx Keyboard Replacement: adım 10, 2 resimden 1. HP Mini 110-3735dx Keyboard Replacement: adım 10, 2 resimden 2.
    • Gently pull the keyboard cable from the socket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Tyrone Williams
923 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Catania Spring 2016 UMass Dartmouth, Team 4-1, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 1,074
