Ana içeriğe geç
HP Mini 110-3735dx RAM Replacement
  1. HP Mini 110-3735dx RAM Replacement, Battery: adım 1, 3 resimden 1. HP Mini 110-3735dx RAM Replacement, Battery: adım 1, 3 resimden 2. HP Mini 110-3735dx RAM Replacement, Battery: adım 1, 3 resimden 3.
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
    FixBot'a Sor
    Yorum Ekle
  2. HP Mini 110-3735dx RAM Replacement: adım 2, 2 resimden 1. HP Mini 110-3735dx RAM Replacement: adım 2, 2 resimden 2.
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
    FixBot'a Sor
    Yorum Ekle
  3. HP Mini 110-3735dx RAM Replacement, Backcover: adım 3, 3 resimden 1. HP Mini 110-3735dx RAM Replacement, Backcover: adım 3, 3 resimden 2. HP Mini 110-3735dx RAM Replacement, Backcover: adım 3, 3 resimden 3.
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
    FixBot'a Sor
    Yorum Ekle
  4. HP Mini 110-3735dx RAM Replacement, RAM: adım 4, 2 resimden 1. HP Mini 110-3735dx RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Push the two white holders holding the RAM outward until it points upwards at about a 45 degree angle.
    FixBot'a Sor
    Yorum Ekle
  5. HP Mini 110-3735dx RAM Replacement: adım 5, 2 resimden 1. HP Mini 110-3735dx RAM Replacement: adım 5, 2 resimden 2.
    • Gently pull the RAM from it's socket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tyrone Williams
923 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Catania Spring 2016 UMass Dartmouth, Team 4-1, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G1
4 Üyeler
1Rehber Yorum
Thank you! It was easy!
zeppo1207 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 1,239
