Ana içeriğe geç
HP Mini 110-3735dx Screen Replacement
Neye ihtiyacın var
  1. HP Mini 110-3735dx Screen Replacement, Battery: adım 1, 3 resimden 1. HP Mini 110-3735dx Screen Replacement, Battery: adım 1, 3 resimden 2. HP Mini 110-3735dx Screen Replacement, Battery: adım 1, 3 resimden 3.
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Screen Replacement: adım 2, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 2, 2 resimden 2.
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Screen Replacement, Backcover: adım 3, 3 resimden 1. HP Mini 110-3735dx Screen Replacement, Backcover: adım 3, 3 resimden 2. HP Mini 110-3735dx Screen Replacement, Backcover: adım 3, 3 resimden 3.
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Screen Replacement, Keyboard: adım 4, 2 resimden 1. HP Mini 110-3735dx Screen Replacement, Keyboard: adım 4, 2 resimden 2.
    • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Screen Replacement: adım 5, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 5, 2 resimden 2.
    • Flip the laptop over, and open it up.
    • Don't worry! No pieces will fall out.
  6. HP Mini 110-3735dx Screen Replacement: adım 6, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 6, 2 resimden 2.
    • With the keyboard facing you, pull the black bezel upward until its loose.
    • You should hear three clicks.
  7. HP Mini 110-3735dx Screen Replacement: adım 7, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 7, 2 resimden 2.
    • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
  8. HP Mini 110-3735dx Screen Replacement: adım 8, 1 resimden 1.
    • Pull up the keyboard from the bottom corners exposing the keyboard cable.
  9. HP Mini 110-3735dx Screen Replacement: adım 9, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 9, 2 resimden 2.
    • Lift the black holder connected to the keyboard cable until it points up.
  10. HP Mini 110-3735dx Screen Replacement: adım 10, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 10, 2 resimden 2.
    • Gently pull the keyboard cable from the socket.
  11. HP Mini 110-3735dx Screen Replacement, Hard Drive Cage: adım 11, 1 resimden 1.
    • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
  12. HP Mini 110-3735dx Screen Replacement: adım 12, 3 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 12, 3 resimden 2. HP Mini 110-3735dx Screen Replacement: adım 12, 3 resimden 3.
    • Lift the hard drive cage by pulling the tape upward.
    • Start by pulling the tape from the side with the keyboard symbol.
  13. HP Mini 110-3735dx Screen Replacement: adım 13, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 13, 2 resimden 2.
    • Unplug the cable connecting to the hard drive.
  14. HP Mini 110-3735dx Screen Replacement, Screen: adım 14, 2 resimden 1. HP Mini 110-3735dx Screen Replacement, Screen: adım 14, 2 resimden 2.
    • Remove the 8 5.0 mm screws under the keyboard using a Phillips #1 screw driver.
  15. HP Mini 110-3735dx Screen Replacement: adım 15, 3 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 15, 3 resimden 2. HP Mini 110-3735dx Screen Replacement: adım 15, 3 resimden 3.
    • Lift the two black holders upward located next to the socket for the keyboard close to the tracked pad.
  16. HP Mini 110-3735dx Screen Replacement: adım 16, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 16, 2 resimden 2.
    • Remove the two connectors for the motherboard from their sockets.
  17. HP Mini 110-3735dx Screen Replacement: adım 17, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 17, 2 resimden 2.
    • Close the laptop by bringing the screen down.
    • Flip the laptop over to the other side.
  18. HP Mini 110-3735dx Screen Replacement: adım 18, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 18, 2 resimden 2.
    • Remove the 6 5.0 mm screws holding the back plate together using a Phillips #1 screw driver.
  19. HP Mini 110-3735dx Screen Replacement: adım 19, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 19, 2 resimden 2.
    • Remove the 2 3.0 mm screw head holding the plastic piece in place using a Phillips #1 screw driver.
    • Located on the left and right side where the battery was removed.
  20. HP Mini 110-3735dx Screen Replacement: adım 20, 3 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 20, 3 resimden 2. HP Mini 110-3735dx Screen Replacement: adım 20, 3 resimden 3.
    • Pull the black plastic pieces that the screws was holding inward.
    • The pieces are located on the left and right corners connecting the bottom and top of the HP Mini.
  21. HP Mini 110-3735dx Screen Replacement: adım 21, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 21, 2 resimden 2.
    • Flip the laptop back over.
    • Open it by lifting the screeen.
  22. HP Mini 110-3735dx Screen Replacement: adım 22, 3 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 22, 3 resimden 2. HP Mini 110-3735dx Screen Replacement: adım 22, 3 resimden 3.
    • Right next to the previous plastic piece, remove the other two plastic pieces.
    • This may be difficult to come off. Tilt the screen back and forth to help loosen the piece.
  23. HP Mini 110-3735dx Screen Replacement: adım 23, 1 resimden 1.
    • Using the plastic prying tool, pry the front plate of the bottom part of your HP Mini.
    • Start along the speaker grill near the touch pad, and move along the sides.
  24. HP Mini 110-3735dx Screen Replacement: adım 24, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 24, 2 resimden 2.
    • Lift up the front plate where the keyboard was.
  25. HP Mini 110-3735dx Screen Replacement: adım 25, 3 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 25, 3 resimden 2. HP Mini 110-3735dx Screen Replacement: adım 25, 3 resimden 3.
    • Remove the display cable from the motherboard located on the top left corner under where the keyboard was by pulling on the black tab.
    • Move the cable.
  26. HP Mini 110-3735dx Screen Replacement: adım 26, 3 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 26, 3 resimden 2. HP Mini 110-3735dx Screen Replacement: adım 26, 3 resimden 3.
    • Remove the webcam cables from the motherboard.
    • Located on the back side of the laptop in the bottom left corner.
  27. HP Mini 110-3735dx Screen Replacement: adım 27, 1 resimden 1.
    • Flip over the computer, and open the laptop.
    • Lift up the front plate on the top right corner.
  28. HP Mini 110-3735dx Screen Replacement: adım 28, 3 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 28, 3 resimden 2. HP Mini 110-3735dx Screen Replacement: adım 28, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Pull the cables for the web cam out using tweezers.
  29. HP Mini 110-3735dx Screen Replacement: adım 29, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 29, 2 resimden 2.
    • Remove the 2 3.0 mm screws on both sides of the bottom of the display using a Phillips #1 screwdriver.
  30. HP Mini 110-3735dx Screen Replacement: adım 30, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 30, 2 resimden 2.
    • Remove the black plastic piece that the screw was holding on both sides.
    • This will reveal another screw.
  31. HP Mini 110-3735dx Screen Replacement: adım 31, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 31, 2 resimden 2.
    • Remove the 2 3.0 mm screws on both sides using a Phillips #1 screw driver.
    • When removing, keep hold of the screen to make sure it doesn't fall.
  32. HP Mini 110-3735dx Screen Replacement: adım 32, 1 resimden 1.
    • Pry the front plate using the plastic opening tool by pushing along the border of the front and back plate.
    • Make sure to pry from the sides, top and bottom as the corners will come undone themselves.
  33. HP Mini 110-3735dx Screen Replacement: adım 33, 3 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 33, 3 resimden 2. HP Mini 110-3735dx Screen Replacement: adım 33, 3 resimden 3.
    • Remove the front plate.
    • Pull the cables through the holes.
  34. HP Mini 110-3735dx Screen Replacement: adım 34, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 34, 2 resimden 2.
    • Remove the 4 4.0 mm screws holding the screen in place using a Phillips #1 screw driver.
  35. HP Mini 110-3735dx Screen Replacement: adım 35, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 35, 2 resimden 2.
    • Lift the screen up.
  36. HP Mini 110-3735dx Screen Replacement: adım 36, 2 resimden 1. HP Mini 110-3735dx Screen Replacement: adım 36, 2 resimden 2.
    • Under the screen, peel off the tape near the cable completely, so you can see the socket for the cable.
Sonuç
Tyrone Williams
905 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Catania Spring 2016 UMass Dartmouth, Team 4-1, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G1
4 Üyeler
Bir Yorum
Tengo una pregunta en pantalla habrá alguna otra que sea compatible con esta hp sin ser el mismo modelo?
Icela Ross - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 801
