Ana içeriğe geç
HP Mini 210 Hard Drive Replacement
Neye ihtiyacın var
    1. HP Mini 210 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP Mini 210 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
      • Turn off and unplug the netbook before replacing the battery.
      • Hold the netbook top-side down with the lid closed.
      • Slide the plastic battery release latches towards the lock symbols.
      • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
      FixBot'a Sor
      Yorum Ekle
    2. HP Mini 210 Hard Drive Replacement: adım 2, 1 resimden 1.
      • Slide the battery out from the netbook.
      FixBot'a Sor
      Yorum Ekle
    1. HP Mini 210 Hard Drive Replacement, Disassembling HP Mini 210 Back Case: adım 3, 1 resimden 1.
      • Turn the netbook to view its edge.
      • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
      FixBot'a Sor
      Yorum Ekle
    2. HP Mini 210 Hard Drive Replacement: adım 4, 1 resimden 1.
      • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
      FixBot'a Sor
      Yorum Ekle
    3. HP Mini 210 Hard Drive Replacement: adım 5, 1 resimden 1.
      • Pull the back case off from the front edge.
      FixBot'a Sor
      Yorum Ekle
    1. HP Mini 210 Hard Drive Replacement, Hard Drive: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Peel back the black sticker covering the hard drive with tweezers or your fingers.
      FixBot'a Sor
      Yorum Ekle
    2. HP Mini 210 Hard Drive Replacement: adım 7, 1 resimden 1.
      • Use a plastic opening tool to carefully disconnect the hard drive connector found above the RAM slot.
      FixBot'a Sor
      Yorum Ekle
    3. HP Mini 210 Hard Drive Replacement: adım 8, 2 resimden 1. HP Mini 210 Hard Drive Replacement: adım 8, 2 resimden 2.
      • Pull the silver plastic tab up and remove the hard drive. The tab may also be black.
      • Be aware of the 4 foam cushions on each corner of the hard drive as they may become loose during removal.
      FixBot'a Sor
      Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Heather Freed
723 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G17
3 Üyeler
96 adet Kılavuz yazıldı
1Rehber Yorum
Be aware that some models don't have buttons but a orange switch that need some pressure to release the cover
Alejandro - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 123
Her zaman: 19,482
