Ana içeriğe geç
HP Mini 210 WiFi Card Replacement
Neye ihtiyacın var
  1. HP Mini 210 WiFi Card Replacement, Battery: adım 1, 2 resimden 1. HP Mini 210 WiFi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 WiFi Card Replacement: adım 2, 1 resimden 1.
    • Slide the battery out from the netbook.
  3. HP Mini 210 WiFi Card Replacement, Disassembling HP Mini 210 Back Case: adım 3, 1 resimden 1.
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 WiFi Card Replacement: adım 4, 1 resimden 1.
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 WiFi Card Replacement: adım 5, 1 resimden 1.
    • Pull the back case off from the front edge.
  6. HP Mini 210 WiFi Card Replacement, WiFi Card: adım 6, 1 resimden 1.
    • Pop out the two gold connectors from the antenna wires on top of the WiFi card using a plastic opening tool. This will allow you to dislodge the WiFi card from the rest of the netbook.
  7. HP Mini 210 WiFi Card Replacement: adım 7, 1 resimden 1.
    • Remove the two 3.9 mm screws on top of the WiFi card using the Phillips #00 screwdriver.
  8. HP Mini 210 WiFi Card Replacement: adım 8, 1 resimden 1.
    • Gently pull the WiFi card out of its slot. Be sure to pull the card up and out of the slot towards you.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Heather Freed
723 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G17
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 43
Her zaman: 5,707
