Ana içeriğe geç
HP Mini 210-1035la Keyboard Replacement
Neye ihtiyacın var
  1. HP Mini 210-1035la Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. HP Mini 210-1035la Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Shut down the computer
    • Flip the computer upside down
    • Remove the battery by sliding its tabs in and pulling it away from the laptop.
  2. HP Mini 210-1035la Keyboard Replacement, Rubber feet: adım 2, 1 resimden 1.
    • Remove the 4 rubber feet
  3. HP Mini 210-1035la Keyboard Replacement, Removing service cover: adım 3, 1 resimden 1.
    • Simultaneously press in on the right release button (1) to release the right side ofrece the service cover (2)
    • Simultaneously press in on the left release button (3) to release the left side of the service cover (4)
    • Reverse this procedure to insert the service cover
  4. HP Mini 210-1035la Keyboard Replacement, Keyboard's screws: adım 4, 2 resimden 1. HP Mini 210-1035la Keyboard Replacement, Keyboard's screws: adım 4, 2 resimden 2.
    • Remove the three screws (circled in red) that hold the keyboard
    • With the computer facing you, turn it right-side up.
    • Completely open the computer
  5. HP Mini 210-1035la Keyboard Replacement, Remove keyboard: adım 5, 3 resimden 1. HP Mini 210-1035la Keyboard Replacement, Remove keyboard: adım 5, 3 resimden 2. HP Mini 210-1035la Keyboard Replacement, Remove keyboard: adım 5, 3 resimden 3.
    • Lift the back edge of the key board until it rest at an angle
    • Slide the keyboard back until the keyboard cable and connector are accessible
    • Release the connector to which the keyboard cable has been attaching, and then disconnect the keyboard cable
    • Remove the keyboard
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Internet Libre
718 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,336
