Ana içeriğe geç
HP Mini 210-1199DX CMOS Battery Replacement
Neye ihtiyacın var
  1. HP Mini 210-1199DX CMOS Battery Replacement, Battery: adım 1, 2 resimden 1. HP Mini 210-1199DX CMOS Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  2. HP Mini 210-1199DX CMOS Battery Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the device.
    FixBot'a Sor
    Yorum Ekle
  3. HP Mini 210-1199DX CMOS Battery Replacement, Bottom Cover: adım 3, 1 resimden 1.
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
    FixBot'a Sor
    Yorum Ekle
  4. HP Mini 210-1199DX CMOS Battery Replacement: adım 4, 3 resimden 1. HP Mini 210-1199DX CMOS Battery Replacement: adım 4, 3 resimden 2. HP Mini 210-1199DX CMOS Battery Replacement: adım 4, 3 resimden 3.
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
    FixBot'a Sor
    Yorum Ekle
  5. HP Mini 210-1199DX CMOS Battery Replacement: adım 5, 1 resimden 1.
    • Pull the case off of the device
    FixBot'a Sor
    Yorum Ekle
  6. HP Mini 210-1199DX CMOS Battery Replacement, CMOS Battery: adım 6, 2 resimden 1. HP Mini 210-1199DX CMOS Battery Replacement, CMOS Battery: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Simply pull the small black ribbon off of the battery with either your finger or a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  7. HP Mini 210-1199DX CMOS Battery Replacement: adım 7, 2 resimden 1. HP Mini 210-1199DX CMOS Battery Replacement: adım 7, 2 resimden 2.
    • Using the spudger, carefully pop the battery out of the right side as seen in the picture.
    • To reinstall, carefully place slide the battery back into place with the positive side facing upwards.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Phillip Winston
655 İtibar
6 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S46-G3, Bennett Spring 2017 Texas Tech, Team S46-G3, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S46G3
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 1,074
