Ana içeriğe geç
HP Mini 210-1199DX RAM Replacement
Neye ihtiyacın var
  1. HP Mini 210-1199DX RAM Replacement, Battery: adım 1, 2 resimden 1. HP Mini 210-1199DX RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  2. HP Mini 210-1199DX RAM Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the device.
    FixBot'a Sor
    Yorum Ekle
  3. HP Mini 210-1199DX RAM Replacement, Bottom Cover: adım 3, 1 resimden 1.
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
    FixBot'a Sor
    Yorum Ekle
  4. HP Mini 210-1199DX RAM Replacement: adım 4, 3 resimden 1. HP Mini 210-1199DX RAM Replacement: adım 4, 3 resimden 2. HP Mini 210-1199DX RAM Replacement: adım 4, 3 resimden 3.
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
    FixBot'a Sor
    Yorum Ekle
  5. HP Mini 210-1199DX RAM Replacement: adım 5, 1 resimden 1.
    • Pull the case off of the device
    FixBot'a Sor
    Yorum Ekle
  6. HP Mini 210-1199DX RAM Replacement, RAM: adım 6, 1 resimden 1.
    • Locate RAM systems.
    FixBot'a Sor
    Yorum Ekle
  7. HP Mini 210-1199DX RAM Replacement: adım 7, 1 resimden 1.
    • Use spudger to carefully pull the holding devices back.
    • RAM should pop out once this is completed.
    FixBot'a Sor
    Yorum Ekle
  8. HP Mini 210-1199DX RAM Replacement: adım 8, 1 resimden 1.
    • Carefully pull the RAM card out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Phillip Winston
655 İtibar
6 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S46-G3, Bennett Spring 2017 Texas Tech, Team S46-G3, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S46G3
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 616
