Ana içeriğe geç
HP Mini 210-1199DX Wireless Card Replacement
Neye ihtiyacın var
  1. HP Mini 210-1199DX Wireless Card Replacement, Battery: adım 1, 2 resimden 1. HP Mini 210-1199DX Wireless Card Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX Wireless Card Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the device.
  3. HP Mini 210-1199DX Wireless Card Replacement, Bottom Cover: adım 3, 1 resimden 1.
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX Wireless Card Replacement: adım 4, 3 resimden 1. HP Mini 210-1199DX Wireless Card Replacement: adım 4, 3 resimden 2. HP Mini 210-1199DX Wireless Card Replacement: adım 4, 3 resimden 3.
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX Wireless Card Replacement: adım 5, 1 resimden 1.
    • Pull the case off of the device
  6. HP Mini 210-1199DX Wireless Card Replacement, Wireless Card: adım 6, 1 resimden 1.
    • Locate the Wireless Card.
  7. HP Mini 210-1199DX Wireless Card Replacement: adım 7, 1 resimden 1.
    • With fingers or tweezers, carefully pull the black and white wire connectors from their sockets and move them to the side.
  8. HP Mini 210-1199DX Wireless Card Replacement: adım 8, 2 resimden 1. HP Mini 210-1199DX Wireless Card Replacement: adım 8, 2 resimden 2.
    • With a Phillip's Screwdriver, firmly but slowly remove the two screws from the top of the wireless card.
    • Be careful not to strip the nail head.
  9. HP Mini 210-1199DX Wireless Card Replacement: adım 9, 1 resimden 1.
    • Pull the wireless card out.
Sonuç
Phillip Winston
655 İtibar
6 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S46-G3, Bennett Spring 2017 Texas Tech, Team S46-G3, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S46G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 389
