Ana içeriğe geç
HP Mini 210-2070NR Battery and Service Access Cover Replacement
  1. HP Mini 210-2070NR Battery and Service Access Cover Replacement, Battery and Service Access Cover: adım 1, 1 resimden 1.
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Battery and Service Access Cover Replacement: adım 2, 3 resimden 1. HP Mini 210-2070NR Battery and Service Access Cover Replacement: adım 2, 3 resimden 2. HP Mini 210-2070NR Battery and Service Access Cover Replacement: adım 2, 3 resimden 3.
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Battery and Service Access Cover Replacement: adım 3, 3 resimden 1. HP Mini 210-2070NR Battery and Service Access Cover Replacement: adım 3, 3 resimden 2. HP Mini 210-2070NR Battery and Service Access Cover Replacement: adım 3, 3 resimden 3.
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Battery and Service Access Cover Replacement: adım 4, 1 resimden 1.
    • Orient the computer as shown in the picture.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sean Kuster
91 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G23
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,471
