Ana içeriğe geç
HP Mini 210-2070NR RTC Battery Replacement
Neye ihtiyacın var
  1. HP Mini 210-2070NR RTC Battery Replacement, Battery and Service Access Cover: adım 1, 1 resimden 1.
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR RTC Battery Replacement: adım 2, 3 resimden 1. HP Mini 210-2070NR RTC Battery Replacement: adım 2, 3 resimden 2. HP Mini 210-2070NR RTC Battery Replacement: adım 2, 3 resimden 3.
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR RTC Battery Replacement: adım 3, 3 resimden 1. HP Mini 210-2070NR RTC Battery Replacement: adım 3, 3 resimden 2. HP Mini 210-2070NR RTC Battery Replacement: adım 3, 3 resimden 3.
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR RTC Battery Replacement: adım 4, 1 resimden 1.
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: adım 5, 3 resimden 1. HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: adım 5, 3 resimden 2. HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: adım 5, 3 resimden 3.
    • The RTC battery is a thin disk near the bottom left corner.
    • The black and red cable is the RTC battery cable.
    • Pull the RTC battery cable out of its socket.
  6. HP Mini 210-2070NR RTC Battery Replacement: adım 6, 2 resimden 1. HP Mini 210-2070NR RTC Battery Replacement: adım 6, 2 resimden 2.
    • Gently pry the RTC battery upward with the plastic opening tool.
    • Remove RTC battery.
    • The RTC battery is attached with double sided tape.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alek Linquist
123 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-23, Amido Fall 2012 Cal Poly, Team 3-23, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G23
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 1,263
