Giriş
If your HP Mini 311 has ran out of memory or you desire to have more memory, change the hard drive on your device.
Neye ihtiyacın var
Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
4 farklı kişi bu kılavuzu tamamladı.
