Ana içeriğe geç
HP Mini 311 Hard Drive Replacement
Neye ihtiyacın var
  1. HP Mini 311 Hard Drive Replacement, Battery: adım 1, 3 resimden 1. HP Mini 311 Hard Drive Replacement, Battery: adım 1, 3 resimden 2. HP Mini 311 Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 Hard Drive Replacement: adım 2, 2 resimden 1. HP Mini 311 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the battery away from the device to remove.
  3. HP Mini 311 Hard Drive Replacement, Memory Shield: adım 3, 1 resimden 1.
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 Hard Drive Replacement: adım 4, 2 resimden 1. HP Mini 311 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 1. HP Mini 311 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 2. HP Mini 311 Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 3.
    • Grab the left black, plastic tab and carefully pull upward.
    • Be sure to pull carefully. Pulling too forcefully may damage the tab.
  6. HP Mini 311 Hard Drive Replacement: adım 6, 3 resimden 1. HP Mini 311 Hard Drive Replacement: adım 6, 3 resimden 2. HP Mini 311 Hard Drive Replacement: adım 6, 3 resimden 3.
    • Grab a hold of the wire connecting the hard drive and the device.
    • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Christian Santoyo
495 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-4, Maness Winter 2013 Cal Poly, Team 20-4, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G4
4 Üyeler
Bir Yorum
What size hard drive does this unit take?
Travis Duncan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 4,328
