Ana içeriğe geç
HP Mini 311 Keyboard Replacement
Neye ihtiyacın var
  1. HP Mini 311 Keyboard Replacement, Battery: adım 1, 3 resimden 1. HP Mini 311 Keyboard Replacement, Battery: adım 1, 3 resimden 2. HP Mini 311 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
    FixBot'a Sor
    Yorum Ekle
  2. HP Mini 311 Keyboard Replacement: adım 2, 2 resimden 1. HP Mini 311 Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the battery away from the device to remove.
    FixBot'a Sor
    Yorum Ekle
  3. HP Mini 311 Keyboard Replacement, Memory Shield: adım 3, 1 resimden 1.
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
    FixBot'a Sor
    Yorum Ekle
  4. HP Mini 311 Keyboard Replacement: adım 4, 2 resimden 1. HP Mini 311 Keyboard Replacement: adım 4, 2 resimden 2.
    • Lift the memory shield up and remove from the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. HP Mini 311 Keyboard Replacement, Hard Drive: adım 5, 3 resimden 1. HP Mini 311 Keyboard Replacement, Hard Drive: adım 5, 3 resimden 2. HP Mini 311 Keyboard Replacement, Hard Drive: adım 5, 3 resimden 3.
    • Grab the left black, plastic tab and carefully pull upward.
    • Be sure to pull carefully. Pulling too forcefully may damage the tab.
    FixBot'a Sor
    Yorum Ekle
  6. HP Mini 311 Keyboard Replacement: adım 6, 3 resimden 1. HP Mini 311 Keyboard Replacement: adım 6, 3 resimden 2. HP Mini 311 Keyboard Replacement: adım 6, 3 resimden 3.
    • Grab a hold of the wire connecting the hard drive and the device.
    • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. HP Mini 311 Keyboard Replacement, Keyboard: adım 7, 1 resimden 1.
    • Unscrew the four Phillip 00 5.6 mm screws located around the wireless card and RAM.
    FixBot'a Sor
    Yorum Ekle
  8. HP Mini 311 Keyboard Replacement: adım 8, 1 resimden 1.
    • Open the laptop so that the screen and front of the keyboard are both facing the ground.
    • Push on the opening on the back side of the device until the keyboard partially pops out.
    • This opening is located where the original hard drive was set.
    FixBot'a Sor
    Yorum Ekle
  9. HP Mini 311 Keyboard Replacement: adım 9, 3 resimden 1. HP Mini 311 Keyboard Replacement: adım 9, 3 resimden 2. HP Mini 311 Keyboard Replacement: adım 9, 3 resimden 3.
    • Flip the device around and orient it so that the screen and keyboard are facing you.
    • Starting at the right side, work your way towards the left end and remove the keyboard by unhinging the latches attaching it to the base of the device.
    • The right side of the keyboard should be unattached.
    • Be gentle and patient. You don't want to pull the entire keyboard at once, but rather pull by sections.
    FixBot'a Sor
    Yorum Ekle
  10. HP Mini 311 Keyboard Replacement: adım 10, 3 resimden 1. HP Mini 311 Keyboard Replacement: adım 10, 3 resimden 2. HP Mini 311 Keyboard Replacement: adım 10, 3 resimden 3.
    • Carefully pull the ribbon cable connecting the keyboard and the laptop to remove from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Christian Santoyo
495 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-4, Maness Winter 2013 Cal Poly, Team 20-4, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 2,984
