Ana içeriğe geç
HP Mini 311 RAM Replacement
Neye ihtiyacın var
  1. HP Mini 311 RAM Replacement, Battery: adım 1, 3 resimden 1. HP Mini 311 RAM Replacement, Battery: adım 1, 3 resimden 2. HP Mini 311 RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
    FixBot'a Sor
    Yorum Ekle
  2. HP Mini 311 RAM Replacement: adım 2, 2 resimden 1. HP Mini 311 RAM Replacement: adım 2, 2 resimden 2.
    • Slide the battery away from the device to remove.
    FixBot'a Sor
    Yorum Ekle
  3. HP Mini 311 RAM Replacement, Memory Shield: adım 3, 1 resimden 1.
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
    FixBot'a Sor
    Yorum Ekle
  4. HP Mini 311 RAM Replacement: adım 4, 2 resimden 1. HP Mini 311 RAM Replacement: adım 4, 2 resimden 2.
    • Lift the memory shield up and remove from the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. HP Mini 311 RAM Replacement, RAM: adım 5, 3 resimden 1. HP Mini 311 RAM Replacement, RAM: adım 5, 3 resimden 2. HP Mini 311 RAM Replacement, RAM: adım 5, 3 resimden 3.
    • Firmly press on the metal pins located on both sides of the RAM.
    • One side of the RAM will pop up to form a 40 degree angle with the body of the laptop.
    • Simply grab and remove the RAM from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christian Santoyo
495 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-4, Maness Winter 2013 Cal Poly, Team 20-4, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G4
4 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
4 GB modules are not supported it seems.
You may see posts in the HP Support Forum saying that the Mini 311 will accept a 4 GB module. Possibly this is true for the Pavilion DM, but not the Mini 311.
The service manual says only 2GB or 1 GB are supported.
Other people posted that they tried a 4GB module and it did not work.
rafss - Yanıt Paylaş
FYI, The link to buy the suggested part is wrong and not compatible.
Christine Fowler - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 4,137
