Ana içeriğe geç
HP Mini 311 WWAN Card Replacement
Neye ihtiyacın var
  1. HP Mini 311 WWAN Card Replacement, Battery: adım 1, 3 resimden 1. HP Mini 311 WWAN Card Replacement, Battery: adım 1, 3 resimden 2. HP Mini 311 WWAN Card Replacement, Battery: adım 1, 3 resimden 3.
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 WWAN Card Replacement: adım 2, 2 resimden 1. HP Mini 311 WWAN Card Replacement: adım 2, 2 resimden 2.
    • Slide the battery away from the device to remove.
  3. HP Mini 311 WWAN Card Replacement, Memory Shield: adım 3, 1 resimden 1.
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 WWAN Card Replacement: adım 4, 2 resimden 1. HP Mini 311 WWAN Card Replacement: adım 4, 2 resimden 2.
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 WWAN Card Replacement, WWAN Card: adım 5, 3 resimden 1. HP Mini 311 WWAN Card Replacement, WWAN Card: adım 5, 3 resimden 2. HP Mini 311 WWAN Card Replacement, WWAN Card: adım 5, 3 resimden 3.
    • Begin by removing the red and blue wires from the wireless card.
    • Gently remove to avoid damaging the ends of the wires.
  6. HP Mini 311 WWAN Card Replacement: adım 6, 1 resimden 1.
    • Remove the two Phillips 00 3.8mm screws attached to the wireless card.
  7. HP Mini 311 WWAN Card Replacement: adım 7, 3 resimden 1. HP Mini 311 WWAN Card Replacement: adım 7, 3 resimden 2. HP Mini 311 WWAN Card Replacement: adım 7, 3 resimden 3.
    • Lift up the unattached side of the wireless card and pull out to remove.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christian Santoyo
495 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-4, Maness Winter 2013 Cal Poly, Team 20-4, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G4
4 Üyeler
Bir Yorum
I don't have red and blue wires visible, are they tucked behind something? My pcie slot is vacant. What compatible part can i put here to increase speed and/or wireless connectivity?
Samant - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 18
Her zaman: 1,451
