Ana içeriğe geç
HP Mobile Thin Client mt41 Charging Port Replacement
Neye ihtiyacın var
  1. HP Mobile Thin Client mt41 Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the two slots on the bottom of the laptop to unlock the battery.
  2. HP Mobile Thin Client mt41 Charging Port Replacement: adım 2, 2 resimden 1. HP Mobile Thin Client mt41 Charging Port Replacement: adım 2, 2 resimden 2.
    • Pull on both slots outwards as shown in the images to unlock the battery. The battery will not come out if the slots are locked. The battery should easily slide out without much force.
  3. HP Mobile Thin Client mt41 Charging Port Replacement, Back Cover: adım 3, 2 resimden 1. HP Mobile Thin Client mt41 Charging Port Replacement, Back Cover: adım 3, 2 resimden 2.
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  4. HP Mobile Thin Client mt41 Charging Port Replacement: adım 4, 2 resimden 1. HP Mobile Thin Client mt41 Charging Port Replacement: adım 4, 2 resimden 2.
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  5. HP Mobile Thin Client mt41 Charging Port Replacement: adım 5, 1 resimden 1.
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  6. HP Mobile Thin Client mt41 Charging Port Replacement: adım 6, 1 resimden 1.
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
  7. HP Mobile Thin Client mt41 Charging Port Replacement, Charging Port: adım 7, 1 resimden 1.
    • Locate the charging port (pictured here).
  8. HP Mobile Thin Client mt41 Charging Port Replacement: adım 8, 2 resimden 1. HP Mobile Thin Client mt41 Charging Port Replacement: adım 8, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the screw securing the charging port.
    • Remove the charging port with a pair of tweezers. Gently pull it away from the computer base.
  9. HP Mobile Thin Client mt41 Charging Port Replacement: adım 9, 2 resimden 1. HP Mobile Thin Client mt41 Charging Port Replacement: adım 9, 2 resimden 2.
    • Just below the charging port, you will find a connector with a white base and a bundle of wires.
    • Using your fingers, pull the cable directly up and away from the computer base. This should be the same direction that the wires are facing.
    • This should not require much force.
Sonuç
Raul Rodriguez
289 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 365
