Ana içeriğe geç
HP Mobile Thin Client mt41 Fan Replacement
Neye ihtiyacın var
  1. HP Mobile Thin Client mt41 Fan Replacement, Back Cover: adım 1, 2 resimden 1. HP Mobile Thin Client mt41 Fan Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  2. HP Mobile Thin Client mt41 Fan Replacement: adım 2, 2 resimden 1. HP Mobile Thin Client mt41 Fan Replacement: adım 2, 2 resimden 2.
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  3. HP Mobile Thin Client mt41 Fan Replacement: adım 3, 1 resimden 1.
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  4. HP Mobile Thin Client mt41 Fan Replacement: adım 4, 1 resimden 1.
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
  5. HP Mobile Thin Client mt41 Fan Replacement, Fan: adım 5, 2 resimden 1. HP Mobile Thin Client mt41 Fan Replacement, Fan: adım 5, 2 resimden 2.
    • Using a J1 head for your screwdriver, remove the 4 surrounding screws.
  6. HP Mobile Thin Client mt41 Fan Replacement: adım 6, 1 resimden 1.
    • Keep your screws close by, and slowly remove the CPU fan.
  7. HP Mobile Thin Client mt41 Fan Replacement: adım 7, 1 resimden 1.
    • Be mindful of wires, the final step is to unplug the fan from the motherboard, at the base of red and blue wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 356
