Ana içeriğe geç
HP Mobile Thin Client mt41 Optical Disc Drive Replacement
Neye ihtiyacın var
  1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: adım 1, 2 resimden 1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: adım 1, 2 resimden 2.
    • Turn off and unplug your laptop. Also, make sure to disconnect all the external devices.
    • After that, slide the two switches to the indicated directions in order to remove the battery and the back cover.
  2. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: adım 2, 2 resimden 1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: adım 2, 2 resimden 2.
    • Now you're able to remove the battery and the service cover.
    • Slide the battery upward to remove it.
  3. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: adım 3, 3 resimden 1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: adım 3, 3 resimden 2. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: adım 3, 3 resimden 3.
    • Slide the service cover downward.
    • After that, lift the back cover to remove it.
  4. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: adım 4, 3 resimden 1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: adım 4, 3 resimden 2. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: adım 4, 3 resimden 3.
    • Unlock the indicated screw in order to remove the optical drive.
    • Slide the optical drive to completely remove it from the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 425
