Ana içeriğe geç
HP Notebook 15-ay011nr Bottom Cover Replacement
Neye ihtiyacın var
    • Before disassembling the computer, follow these steps:
    • Shut down the computer
    • If you are unsure whether the computer is in hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect all external devices connected to the computer
    • Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer
  1. HP Notebook 15-ay011nr Bottom Cover Replacement, Removing the battery: adım 2, 1 resimden 1.
    • To remove the battery:
    • Position the computer upside down on a flat surface
    • Slide the battery lock latch (1)
    • Slide the battery release latch (2)
    • Remove the battery (3) from the computer
  2. HP Notebook 15-ay011nr Bottom Cover Replacement, Optical Drive: adım 3, 1 resimden 1.
    • To remove the optical drive:
    • Remove the Philips PM2.5x6.0 screw (1)
    • Remove the optical drive (2) by sliding it out of the optical drive bay
  3. HP Notebook 15-ay011nr Bottom Cover Replacement, Bottom Cover: adım 4, 1 resimden 1.
    • To remove the bottom cover:
    • Position the computer upside down the the front toward you
    • Remove the two rubber feet from the rear of the bottom of the computer (1)
    • Remove the 11 Philips PM2.5x6 screws (2) from the bottom of the computer
    • Remove the 2 Philips PM2x2 screws (3) from the optical drive bay
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alec Ringberg
625 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 453
