Giriş
This guide will show you how to replace the optical drive in an HP Notebook 15-ay011nr.
Neye ihtiyacın var
Before disassembling the computer, follow these steps:
Shut down the computer
Disconnect all external devices connected to the computer
Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer
To remove the battery:
Position the computer upside down on a flat surface
Slide the battery lock latch (1)
Slide the battery release latch (2)
Remove the battery (3) from the computer
To remove the optical drive:
Remove the Philips PM2.5x6.0 screw (1)
Remove the optical drive (2) by sliding it out of the optical drive bay
