Ana içeriğe geç
HP Notebook 15-ba018ds Fan Replacement
Neye ihtiyacın var
  1. HP Notebook 15-ba018ds Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
  2. HP Notebook 15-ba018ds Fan Replacement: adım 2, 3 resimden 1. HP Notebook 15-ba018ds Fan Replacement: adım 2, 3 resimden 2. HP Notebook 15-ba018ds Fan Replacement: adım 2, 3 resimden 3.
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
  3. HP Notebook 15-ba018ds Fan Replacement, Fan: adım 3, 2 resimden 1. HP Notebook 15-ba018ds Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that need to be removed.
  4. HP Notebook 15-ba018ds Fan Replacement: adım 4, 1 resimden 1.
    • Use an opening tool to help remove the back cover.
    • If you look at the side of the laptop, you can see where it can be separated into two parts.
  5. HP Notebook 15-ba018ds Fan Replacement: adım 5, 2 resimden 1. HP Notebook 15-ba018ds Fan Replacement: adım 5, 2 resimden 2.
    • Remove the three Phillips head screws attached to the fan.
  6. HP Notebook 15-ba018ds Fan Replacement: adım 6, 2 resimden 1. HP Notebook 15-ba018ds Fan Replacement: adım 6, 2 resimden 2.
    • Remove old fan and replace with a new fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 1,296
