Ana içeriğe geç
HP Notebook 15-ba018ds RAM Replacement
Neye ihtiyacın var
  1. HP Notebook 15-ba018ds RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
    FixBot'a Sor
    Yorum Ekle
  2. HP Notebook 15-ba018ds RAM Replacement: adım 2, 3 resimden 1. HP Notebook 15-ba018ds RAM Replacement: adım 2, 3 resimden 2. HP Notebook 15-ba018ds RAM Replacement: adım 2, 3 resimden 3.
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
    FixBot'a Sor
    Yorum Ekle
  3. HP Notebook 15-ba018ds RAM Replacement, RAM: adım 3, 2 resimden 1. HP Notebook 15-ba018ds RAM Replacement, RAM: adım 3, 2 resimden 2.
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that you unscrew.
    FixBot'a Sor
    Yorum Ekle
  4. HP Notebook 15-ba018ds RAM Replacement: adım 4, 1 resimden 1.
    • Use an opening tool and wedge it under the edge and go around the whole laptop to help remove the back cover.
    • On the side of the laptop, you can see where it can be separated into two parts.
    FixBot'a Sor
    Yorum Ekle
  5. HP Notebook 15-ba018ds RAM Replacement: adım 5, 3 resimden 1. HP Notebook 15-ba018ds RAM Replacement: adım 5, 3 resimden 2. HP Notebook 15-ba018ds RAM Replacement: adım 5, 3 resimden 3.
    • This laptop has one RAM.
    • Gently pull out the RAM from the socket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 1,614
