Ana içeriğe geç
HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement
Neye ihtiyacın var
  1. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement, Manual One-Inch Paper-Feed Roller: adım 1, 2 resimden 1. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement, Manual One-Inch Paper-Feed Roller: adım 1, 2 resimden 2.
    • Open the document feeder cover by flipping it to the left with the front panel facing you.
    • The document feeder is designed to be a bit more difficult to open, so it is okay to use a little more force.
  2. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: adım 2, 3 resimden 1. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: adım 2, 3 resimden 2. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: adım 2, 3 resimden 3.
    • Locate the manual one-inch paper-feed roller end of the document feeder cover.
    • Remove the 11.0mm screw on the side of the roller with 2.0mm hex screwdriver.
  3. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: adım 3, 3 resimden 1. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: adım 3, 3 resimden 2. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: adım 3, 3 resimden 3.
    • Pull the side cover of the manual one-inch paper-feed roller to the right and remove the paper roller.
Sonuç
Stephanie Carpintero
994 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G6, Livingston Winter 2018 Cal Poly, Team S19-G6, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S19G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 40
Her zaman: 1,849
